Fruity Loops 5 linked to Cubase
  • Thread starter Thread starter Alexrkstr
A
Alexrkstr
Member
Hey guys,
How can I record any of the FL synth into cubase?
I know how to load FL into the VSTi but I can't come back to Cubase (SX 2.2) and record the synth sound I want.
Thanks!
If its like Cakewalk...
I switched to Cakewalk a couple of years ago, but I'm guessing the operation is pretty similar. Since no Steinbergers have responded, I'll give it a shot. Conceptually, you have to keep in mind that there are two song layouts you're working with (the main panel in Cubase and the ?playlist? in FL), and while you can't view them simultaneously, they both play at the same time. If you want a FL synth playing at measure 8 in the main song, you have to add it in FL at measure 8.
After having added the instrument to your softsynth rack, you have to do all your programming of FL instruments in FL (using their piano roll, etc.) - make sure you add your patterns/loops to the playlist. Playing the song in FL should generate all the synth sounds you've programmed. Once you have what you want in FL, close it out. Back in your Cubase, you should be able to just press play, and everything you did in FL should be coming through on the FL audio channel(s) in Cubase.
Hope some of that helps. End of rambling.
Simply run FLoops as a VSTi set up a midi channel and have FL as the output, record the stuff either in the midi editor or FL, you can then export your F loops music as audio straight into an audio track by soloing it and going to export audio in the file menu, make sure you tick export into audio Track
Alexrkstr said:
Hey guys,
Thanks!
file : exit
It will then go back to cubase with the small VSTi FL image and you can set the midi channel and go for it.
