Fostex dmt8vl mixdown
  • Thread starter Thread starter Joet
J
Joet
I want to mix down digitily to a Phillips cdrw . Can I do thos thru thru the optical i/o on both?
Thx
Joe
Yes you can... just plug in an optical cable(Fiber optic cable)out of the Fostex and into the CD recorder.
Sincerely;
Dom Franco
Is it that simple? Will their be any tricks to sync them? I would appreciate your thoughts
Are than any other thougths on how to mix down from the fostex with an internal hard drive. The dealer said that I would need to archive to a digital tape machine. I can't afford both a cdwr and a dat machine so I figured I could as long as I was happy with the mix just make copys of the cd to use for demos
I aoppreciate your help
Thx
Joe
make several mixes before you re-use the space on the hard drive. Then you will have a choice later on to pick from.
Dom
It sounds like there were two parts to your question --- mixing and archiving:
You can archive your multi-track recordings from the DMT-8vl to DAT or even to recordable CD. If you are going to CD, though, just make sure you disable the automatic tracking number feature. You want to record all 8 tracks to the CD recorder like it were all one song. It gets recorded sequentially ---- but it does work pretty well --- I've done this millions of times without a glitch. Make sure you follow the directions in the manual and you can archive any multi-track song yopu have to reload later for new mixes.
