Level Anything
Member
I bought two Fostex 1/4" 8-tracks recently (A8, Model 80). Both were serviced about 5 years ago and although they hadn't been used since, are in really nice shape. The heads are good, all the VU meters on the A8 light up and work, and the LED meters on the M80 do the same. Just two solid machines that both sound awesome. The issue I'm having is that the rewind on both of them is messed up.
I've looked all over the web, including here, and haven't read a problem/solution that is applicable to mine so I figured I'd throw it to you guys and see if anyone here could help me out? Here's the issue exactly.
On the Model 80. I put in fresh tape and play it to around 30 sec on the counter and hit reset. If I record a 2-3 min track, hit stop and then either press "Zero Return" or Rewind, the left reel struggles to pull the tape back. I can help it out by twisting the reel clamp knob and get it going, and it will start to get some speed and eventually stop at zero, but it won't rewind without a gentle twist to get it going.
The same issue happens on the A8. One thing I've noticed is that if I FF to the middle of the tape, so that there's more or less an equal amount of tape on each reel, then I can press RW and they both will rewind without having to be helped. I cleaned the tape path on both of these and have taken the face off them too, just to see if it was a belt problem or something that I could observe, but everything looks fine. I'm stumped.
Before I take them into NJ Factory Service, which could end up costing me some money that I really don't have, I figure I'd take one last shot and ask around here. If anyone's had any experience with these, or any machines like these, then please let me know what you did. Much appreciation. JR
