C
caleb2438
Does Anybody know how to format the C drive using Xp Home edition?
RichHead said:I BELIEVE Home Edition will only let you change the type of file system you have....from FAT32 to NTFS. To reformat, you are going to need to boot into DOS from a floppy most likely....
Then type in "format c:" at the prompt.
If you want to set up partitions, before you format is a good time to do it.
Disk Deframenter should report any damaged areas or "clusters" on your disk. Refer to the color table in defrag. for that, I forget which color means damaged.
duck said:
You may need to Fdisk then try to Format.
RichHead said:That's what I do. Works like a charm. Never had any errors.
You can have either NTFS Or Fat32. I have Fat32 on my XP.FDISK to format for XP/2K? Are you not running NTFS?
