M
MidoBan
I understand that the Pro 24 has the DSP feature, so i can run stuff like reverb and limiter on the onboard chip and i wont have any strain on my CPU like with a DAW plugin. My question is if those onboard effects can only be used while recording or can i also apply them after the tracks had already been recorded?
For instance, if i recorded something without any reverb at all, and i wanna add some now, can i use the onboard reverb to do it? also, if i recorded using the onboard reverb can i then remove the reverb from the track after i recorded?
Thanks!
Thanks!
