homestudioguy
NICE CHRISTMAS GIFT(S)!
(Units are on top of rack)
2-Focusrite Trakmaster Pro Recording Preamp/Channel Strips with power supplies, factory boxes etc. Very lightly used in non-smoking home studio and well-taken care of.
You can use an XLR microphone OR plug in electric guitars, basses, keyboards etc via the 1/4 inch (TRS) input jack.
This Focusrite Channel Strip model is still current and sells discounted for $339 at Musicians Friend, ZZounds, Sweetwater etc.
Selling them for $200 EACH!!! plus any shipping if needed. Buy both for $375 plus shipping.
If interested, e-mail me at homestudioguy.verizon.net or PM me.
If not local in Central Illinois, can do PayPal.
LOWER 48 STATES ONLY
FOCUSRITE LINK: http://www.focusrite.com/products/platinum/trakmaster_pro/
KEY FEATURES
Award-winning Class A discrete transistor-based Focusrite pre-amps
This pre-amp demonstrates the same wide bandwidth philosophy featured in the original vintage Focusrite units, ensuring low noise and distortion.
'Pro Series' Latency-free monitoring
Monitor your source signals within the mix, directly at source, avoiding having to resort to monitoring via your DAW or digital desk, both of which may be prone to latency issues.
Custom Opto Compression :up:
With the addition of variable attack and the unique ‘Squash’ mode (ideal for intense drum sounds), this compressor gets you the compression sound you need in seconds.
Optional Stereo 24 bit / 96kHz ADC (not included)
Tracking a vocal direct into your DAW or any other digital recording media has never been easier or more affordable. The Platinum Pro ADC provides a stereo digital S/PDIF audio output and can be retro-fitted at any time.
Switchable impedance
The Low Impedance switch brings yet further sound options to your recording, allowing you to get more from your microphone and make the most of ribbon mics, which perform best when combined with a low impedance preamp.
Front Panel Direct Instrument Input
For quick and easy connection without the need for a separate DI box. A High Gain switch provides the option to boost the incoming signal by 20dB - ideal for passive guitars.
Mid Scoop EQ
The Mid-scoop EQ is a quick and effective problem-solver. With two different depths of cut and an adjustable frequency control, it’s ideal for vocal problem solving or for creating great miked-up cabinet ambience.
KEY FEATURES
Mid Scoop EQ
