H
hiphopsupamix
hey guys,
I've put up a basic vocal booth (4 pieces of think plywood hinged together) now I'm told I need to foam the inside of my vocal booth. To clarify, this is to reduce the reflection of sound from the vocalist right?
I've been told a reasonable way to do this is to buy a bag of foam offcuts and stick them up randomly in the booth. To be exact, this is what was told to me;
Then get your bag of foam offcuts and cut them into random shaped blocks that sit no higher than 4cm. You will need to cut up alot of foam pieces. The randomer the shape the better. Once you think you have enough foam to cover the 4 panels, you can stop.
get your quick grip and smother it all over the inside of the frame. Then start sticking the foam pieces randomly all over the panel. You will need to hold the pieces firmly to ensure they stick. Once you have fully covered the sheet, leave it overnight. Repeat this for the other 4 panels.
does this sound ok to achieve a good result for my vocal recording or does anyone have any additional advice or comments?
thanks sooo much for any help!
