kidvybes
...I've been using my RNC patched into the "insert input" of my mixer with TRS cables but now I'd like to hook it directly between my mic pre and my interface input...I only need a single mono connection since I want to use it to track mono vocal sessions...but here's where I get lost...the Amek 9098 is balanced "out" (not transformer balanced out) and the RNC is unbalanced "in"...I've read that "transformer balanced" output can be connected to unbalanced input with a standard mic cable (XLR female to 1/4" male TS with pin 2 "hot" and pin 3 to sleeve)...but since the 9098 is not a transformer balanced output (does that make it an "electronically balanced" out?) I've read that the pin 3 has to be disconnected from the sleeve...read explanation below:
http://www.mediacollege.com/forum/showthread.php?t=4916
...I don't want to try this until I know for sure the proper setup...I want to go from the 9098 (XLR balanced output but not "transformer" balanced) to the RNC (1/4" unbalanced input) and the from the RNC (1/4" unbalanced output) into my M-Audio Omni-Studio (1/4" balanced in)...sounds simple, but that pin 3 issue has got me real confused...help please...
***EDIT***
...I just read this in a review of the 9098:
"The rear panel carries an IEC mains socket with associated voltage selector and fuse holder. A pair of 4mm binding posts with supplied linking bar bring out the chassis earth and analogue ground connections. Microphone inputs and line-level outputs are catered for with 3-pin XLRs; the inputs are electronically balanced but the outputs incorporate substantial transformers."
...so does that mean I can use the "pin 3 to sleeve" configured cable?
***EDIT***
