7string
Ok, I've been lurking here for awhile and fairly new to this forum. Please give my song a listen and tell me what you think.
Thanks!
Thanks!
Emusic said:Great voice. Something weird with the voice mix. More definition maybe (less verb and more high EQ?). Song is pretty predictable but still ok/good. Less verb on the kick and also maybe (just maybe) some more definition with the snare. More definated bass?
I think the overall definition in the mix is lacking. Late in the song I get the feeling that the vocal gets louder (one of the last verses, maybe THE last one). Late it is too loud (lead vocal). Pan and mix the choir a tad more?
Ok song; mix ain't the best imo.
Keep it up.
Rokket said:Yeah, there is some definition lacking toward the end of the lines as you sing them. I get that problem a lot too, and it's not in the mix, it's in how I sang the lines. I tend to trail off and it makes the lyrics melt into the mix and get lost.
Nice tune, it just needs some rework. I'd retrack the vocals, maybe track with a tad bit of compression.
Emusic said:Is it an Alesis SR-16? I have one of those. If you are using a midi sequencer you could try to remake the same rythm by playing one and one rythm element (kick, snare & hat) and get them out on 3 different tracks. Then you should be able to select the snare sound you want, and also put verb on the snare only - not the whole drumkit. Don't know if you are this familiar with midi though.
Definition comes from listening and turning knobs. For definition each track soloed must have some edge/sharpness and the instrument must be king in its own frequency range. Remembering your song, I didn't hear any big frequencyfights between several elements (foundation, vocal, etc..), but its more that there is some dullness and some lack of EQ'ing that makes it.... somewhat dull and not.... defined![]()
EQ'ing is not only about what you add; even more often about what you take away.
SO try to get rid of much of the reverb on stuff first. Then make sure the tracks sound crisp and somewhat sharp on their own. Then try to un-solo a track at the time to see what fits in.
I can't give you much advice on specific frequencies. I normally just twist and turn the knobs and use my ears. I'm no pro![]()
If you cant split the drums then just get rid of some of the verb and add some more mid or high EQ to make the snare sparkle a tad more. But getting the snare on a separate audio or midi track is better. Then you can adjust volumes separately.
Hey; it's not bad. It's just not sparky overall.
jake-owa said:Cut a buttload of the frequencies below 250hz in the vocal.
The snare sound is hard to take. I had an SR 16 so that's probably part of the problem for me hearing it here. There's a bit of overuse of reverb here that is making the mix muddy in general.
I am not too good with it either. I fumble around with it until I find a setting that makes the vocals sit. Generally, I'll start out hard, 6 to 1, and then dial it down...7string said:It's the quieter part that kinda gets buried. I didn't use any compression during tracking, mainly because that's my SECOND Achille's Heel.Still learning about that. Any suggestions on some settings?
Thanks!
scrubs said:The song is pretty good, but the mix is really weird. The vocals and electric guitars sound muddy, but the acoustic and the cymbals have way too much top end. Sounds like you were trying to compensate for the mud by adding some "sparkle," but it really just ends up sounding brittle.
My suggestions:
1) get some mics to record the acoustic guitars - the direct-in from the pickup almost always sounds terrible. miking a guitar amp usually sounds better than recording electrics direct, too.
2) find some better drum samples or, better yet, get a real drummer (I'm in the same boat, so don't feel bad)
3) take some of the effects off of the vocals - you might want to also invest in a decent vocal condenser mic. you have a nice voice. it deserves better.
4) heed the mixing advice that has already been posted.
Keep working on it. There's definitely some potential here.
But where you landed wasn't a bad miss...7string said:Thanks for the compliment on the voice. Believe it or not, I was kinda going for a Rob Thomas/Smooth feel. I missed.
Rokket said:But where you landed wasn't a bad miss...
And having an ART pre isn't as bad as having a NONE, which is what I have at the moment...
7string said:Ok, I'm using an MXL condensor mic through an ART (I know, I know) pre for vocals and the acoustic. I recorded three separate tracks of acoustic and just used different EQ'ing on them and blended them left, center and right. I put the 'normal' sound in the middle and the brighter sound to the right leaving the other to the left. I probably just need to tweak these a bit to bring out more of the normal sound. Oh, and I won't even tell you WHICH acoustic guitar I use. I'd never be able to show my face in public again. hahaha THAT might be part of it, but dammit, I like the sound!
I live in the middle of nowhere in a little village filled mostly with retired people. In 30 years I have never even HEARD of a drummer here.![]()
I'm using verb and delay on the lead vocal and verb on the backups. Not much of either verb or delay, at least in my opinion. But I'll back some off and see what it does.
Invest in musical gear? Nah, I'd just meet a damned woman who would take off with it. Well, in all honesty that's only happened twice. hahahaha
LOL! You haven't heard my AC/DC throwaway have you!7string said:Well, us GOOD one's make do with what we have, right? I have one of those John Fogerty/Bob Seger type voices. I can go silky smooth or big time gravel. Back in the mid-70's I sang all the Kansas and Journey in my bands. And I always wished that I could do the gravel. Well, after 25 years in radio training my voice to stay 'down there' and many years of cigarettes and Jack I can now do the gravel. I can't come anywhere NEAR a Kansas or Journey song, but I can do the gravel!
But I finally gave up the Jack. I was married for 20 years so I EARNED the cigarettes.![]()
scrubs said:Well, if you like it, that's what matters! I am surprised you used a mic for the guitar, though. Your EQ job has faithfully recreated the harsh sound of a piezo pickup. That's impressive, I suppose.![]()
scrubs said:Hang around here and you might find some people to play drums for you in an online collaboration. Technology is really a great thing.
scrubs said:Yeah, I'm not sure which mic you're using (and it may be the ART pre), but the voice just needs to be more up-front in the mix. Less reverb can help with this, too.
Rokket said:LOL! You haven't heard my AC/DC throwaway have you!
It's in the show us your worst thread...![]()
Why not? I got all kinds of comments the first time I posted it because everyone thought I was using a vocal processor set to chipmunk!7string said:Do I dare?
Rokket said:Why not? I got all kinds of comments the first time I posted it because everyone thought I was using a vocal processor set to chipmunk!![]()
Jake dared me to post a dry track of my voice to prove it and I did....
You might find it entertaining...
