H
HomeRec
I'm planning to pick up a microphone for a home recording solution I'm putting together. The primary use for the microphone, at least initially, will be vocals. However, I may eventually want to use it for other applications.
The two microphones I'm presently considering are the Shure SM57 and the Shure SM58. Each has its strengths and weaknesses.
Shure SM57: The all-in-one microphone everyone seems to own, it's a little less expensive than the SM58, and is advertised as being able to do everything. However, the microphone's emphasis seems to be on instrumental applications. Also, for vocal recording, windscreens seem to be a little tougher to find, and a little more expensive.
Shure SM58: This microphone is supposedly tailored for vocal recording, and it is easy to find windscreens for. However, it is a little more expensive than the SM57, and seems to be a bit more of a "one trick pony". That is, it seems as though it is intended for vocals only.
I've listened to both, and they seem to sound similar to each other, with a slight edge going to the SM58. I looked at the response curves for both microphones, and they are different.
So basically, which of the two would be a good first microphone? I know a lot of people have the SM57, but is it a good choice for vocals? Can the SM58 be used effectively for other applications besides vocals? What are some statistics or factors I may be overlooking?
It's a bit confusing, even after reading Harvey Gerst's excellent post on microphones.
Finally, if there is a different microphone in the same price range that is a much better choice, I'd love to hear about it.
