Alright Charlie, today I feel generous so I'm going to give you some free advice.
It's actually a pretty good recording and performance. But here's some EQ tips that I think are going to be very important as you mix in other things:
The toms are a little dominant. Their main frequencies are in a wide area between 100 and 180. Very generally speaking, the kick and the snare should be the most prominent.
Your kick is right where it should be; smack dab at about 80 hz, which is common for most rock drums. Your snare is tuned a little higher than normal, as it resonates around 250 hz. Your kick is just a little buried amongst a lot of low-end rumble and tom action.
If you were able to go back to your mix and fix it, it would be pretty simple. Just turn the toms down, boost the hell out of the kick and snare mics, or both.
If remixing weren't an option and this were what I had to work, this is how I'd EQ it:
* Boost the hell out of 80 hz (more kick)
* Boost 250 hz, as well (more snare)
* Low-shelf everything below 50 hz, and cut off everything below 30 or 40 (will improve definition).
* Make a very significant cut on everything between 100 and 180 hz (will help reduce the volume of the toms)
* Make another significant cut on everything between 500 and 900 hz (will help them fit better in a mix, as this is where a lot of the vocals and guitar will want to reside)
* Boost the heck out of 2.5 hz with a wide Q to bring out more definition on the kick and snare.
* Do a small high-shelf boost on 4 khz on up for a just a touch more crispness in the cymbals.
