T
TheColdWarKid
I needed to turn my SPDIF-optical port on. Should have required the click of just one box. Yeah - RIGHT!
On my way the naysayers were thick, and numerous. "You can't get two outputs from a PC. I did not believe. Too many people doing the same things on a PC, every day. No way ALL of them are going to fail!
Here, after 4 days of looking (no joke) is how it CAN be done!
In the "Virtual Audio Cable" shareware there is a program called "Audio Repeater." It works, with or without the installation of "Virtual Audio Cable." Grab it.
In the "recording devices" pane of your Winblows Mixer, right click on an empty space. Select (check) the Show Disabled Devices. "What You Hear" will appear. Select, and activate it.
Run the Audio Repeater program. As input, select the What You Hear output device. As output select (for example) your SPDIF-optical port, on the back of your sound card.
And voila! Output from TWO devices, in the same PC!
(You could still get Qualudes in the '80s, which may explain the windows "mixer") No one perceived the PC as an audio processor until long after it's inception. Today, it's a PC in name, only, and more than up for the task! Time we USED those eight cores....
