R
renton_marx
Hi everyone
I'm actually playing my second bar gig as a vinyl DJ, but last time my sound was highly compromised. I'm used to using RCAs (red and whites) for my home rig, but the bar I'm playing has a Fender SRM 6302 with six 1/4" inputs. The only cable I had to connect to it was an RCA to 1/4" mono Y adapter, so I had to double up the right speaker as the cue for the left to get sound out the right, which caused havoc if a track I was mixing started to pan.
Getting on to my question, my mixer also has a balanced 1/4" master output, which I'm told has better sound quality than the RCA output I used before anyway. At the risk of sounding stupid, a) are the two balanced master jacks still left and right, hence the name; b) if so, does that mean I need a 2-mono 1/4" to a single stereo 1/4" adapter and I just jack into line 1 on the Fender, or do I run two mono lines from each master on the mixer to lines 1 and 2 on the Fender power mixer; and c) does the balanced master output really have better sound quality than the RCA?
Thank you in advance for any help I may recieve
rm
rm
