T
tspnyc
I got a new computer, with Vista. So my fabulous Aardvark soundcard and breakout box are of no use to me
( It has what were considered the best mic preamps made for computer recording. But Aardvark went out of business anyway, so no Vista drivers will ever be made for the card. And no, I have no interest in uninstalling Vista and installing XP again.
So, I have been looking at a Firewire interface. It is the Alesis IO14 14-Channel FireWire Audio/MIDI Interface. Basically I need four mic ins with preamps. I record acoustic guitar and vocals and not much else.
I am using Cubase SE.
Will this or a similar Firewire unit work for me? I am after as professional a sound as possible, which is why I went with Aardvark and a sound card instead of USB units. This was before PCs were coming with Firewire.
What can I expect from Firewire in terms of issues, integrity, etc.?
Thanks
Here are some specs I got on it. I have a note into the maker to find out if it will work with Vista.
Specifications:
Analog Inputs:
Sample rates: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
Frequency response: +/- 0.05dB from 20Hz to 22kHz
Dynamic range: 112dB, A-weighted
Signal-to-noise ratio: 112 dB, A-weighted, minimum gain
THD+N: 0.001 -0.0015% @ 1kHz/0dBFS
Crosstalk: -110dB @ 1 kHz
Preamplifier THD+N: <0.0007 at 20dB gain
Preamplifier slew rate: 15 volts/microsecond
Microphone gain range: +6.8dB to +50dB
Microphone impedance: 1.2kOhm
Line gain range: -15.4dB to 27.8dB
Line impedance: 16kOhm
Guitar gain range: +6.8dB to +50dB
Guitar impedance: 1 MegaOhm
Turntable Input (IO|26 only):
Frequency response: +/-1dB from published RIAA curve
Dynamic Range: 95dB, A-weighted
Signal-to-noise ratio: 95dB, A-weighted
THD+N: <0.05%
Crosstalk: -100dB @ 1 kHz
Impedance: 47Kohm
Line-Level Outputs
Level: -10dBv/+4dBu nominal (switchable), +19dBu maximum
Frequency response: +/- 0.075 from 20Hz to 22kHz
Features:
24Bit/192kHz Recording for high-quality, pristine recordings
Superior Clock stability with DICE II JET™ Jitter Elimination Technology
Audiophile Cirrus converters to provide maximum dynamic range on inputs and outputs
Flexible, routable Hardware Direct Monitoring and HDM Control Panel software for customizable monitoring mixes (see image below)
Cubase LE software included (Windows and Mac compatible)
Bus or adapter powered
[inputs]
4 Alesis High Definition Mic/Line Preamplifiers built in (2 switchable high-impedance inputs for direct guitar and bass recording)
Switchable Phantom Power for each channel pair
Inserts on every analog channel
8 channels of ADAT input
16 Channels of MIDI I/O
Stereo S/PDIF digital input
[outputs]
2 line-level outputs
2 discrete stereo headphone outputs
Stereo S/PDIF digital output
System Hardware Requirements
PC:
Intel Pentium 4 or AMD Athlon 2.0 Ghz or faster
1 Gig RAM or more
Windows XP Home or Professional Service Pack 2 or higher (Windows XP Media Center Edition is untested)
Thanks
Specifications:
Analog Inputs:
THD+N: <0.05%
Impedance: 47Kohm
Line-Level Outputs
Features:
[inputs]
[outputs]
PC:
1 Gig RAM or more
