Fine, laugh at me, but
  • Thread starter Thread starter Alanfc
Alanfc
Alanfc
I know this has been covered a 1000x, but I have seen no defintive answers or warnings about damage to my power section-
I must know before I try this out-
= Volume boost in the FX loop rather than up front =
so I can get volume increase for solos, without additional preamp distortion (which I have plenty of already)
I will try it with my Blues Driver with Gain at =0=, and with a compressor.
so anything to be scared of?
Well, I did this once using a Carvin Nomad (vintage type amp) and a wah pedal with a 20db boost function, and nothing was damaged as far as I know. If anything, expect the power tubes to not last as long.
I would assume that as long as you are using a tube amp, then there should be no problems.
Thats a good idea. I don't need anymore preamp distortion either...but my amps don't have EFX loops. :(
Some 12ax7 preamp tubes are labeled as 'graded for high gain' but I dont know if those drive the power amp more or if they just create more preamp distortion. I suppose it might make a difference which tube you replace.
It means the preamp tube will break up sooner, and in the end, allowing more gain.
