stevieb
Just another guy, really.
Yesterday, replaced most of the caps on my little Monkey-Wards Model 6000 5-watt amp. Idle hum way down, amp still has a very fuzzy, distorted tone with volume more than half way up- that's okay, it is what it is, and I like it that way, for the most part. Still has the original speaker, which is cheap and old, so I have decided to have some fun.
Existing cab is taller than it is wide, varnished pine, not plywood- amp is either in a replacement, home-built cab, or all the tolex has been removed and the cab varnished. Original grill cloth still on original baffle board, with original speaker (I had one of these as a kid, remember this stuff from then.) I am going to build a new, shorter cab, cover it with a tweed cloth (cheaper vinyl instead of woven cloth) and put two speakers in it- either 6's or 8's. Local speaker rebuilder has a bunch of Fender 12's, pretty cheap, but they are 16-ohm speakers, so I am wary of using two of them.
Which brings up this: how do I determine acceptable speaker inpedence? Original speaker has "24, 6548, SP8300" ink-stamped on magnet cover. There ' something printed on the speaker cone, but I can not read it all. As I recall, my other M-6000 had a speaker transformer, but I am not 100% sure of that, and this one does not- altho this speaker has mounting holes for a transformer, I see no marks to indicate one was ever mounted.
Once I am done with this little project, I hope it sounds much better- I will, as a finishing touch, flip the face plate over, and put some fancy-script name and chicken-head knobs on it, to make it appear to be an expensive botique amp. Then I will bring it to too-big-guitar-group rehersal, and parade it before my band mate who has turned his nose up at it, just to see what he says THEN. Of course, I will pretend it is an expensive botique amp.
Other suggestions appreciated, too. And yes, Light, I will even listen to you...
