A
armack
I am using a digi02 and I have some songs that I would like to master through a finalizer96k. I have recorded my sessions at 96kh. Right now the way I have been doing my final bounce to disk is to put a spdif insert on the master fader of the pro tools session. Then right under that insert I put a L1 ultra maximizer which I only use for the dither. Then after making my setting on the finalizer I bounce the session to disk and set the conversion to 44.1kh 16 bit stereo.
I monitor through my digi02 when I am setting up the finalizer, would it be better to monitor from the analog out of the finalizer?
Should I get a cd recorder that would accept spdif, and send the output of the finalizer to it. I could then do the dither with the finalizer, and I wouldn’t have to put it as in insert on the master fader.
And on a slightly different topic, I have the digi02 getting its clock from the finalizer, is that a bad idea?
Thanks for any advice.
