Faulty Audio Buddy, or Me?
  • Thread starter Thread starter rathpy
R
rathpy
According to the manual the Buddy's green signal lights are supposed to show the presence of a signal for either the rear XLR or front jack. The signal lights on mine only comes on for the front instrument only, not for the rear XLR’s! (And of course I don’t have an instrument pluged in at the same time as the XLR). I hear a healthy signal from the XLR but no light. Does yours operate this way?
My new Audio Buddy has the M-Audio label on it rather than Midiman. Is this the older or newer version?
The M-Audio manual supplied lists the Power supply specs as 9VAC, 500mA, however the label on the external power supply (that came in a separate box, because it’s 240v mains here) says only 300mA! So is it underpowered? I notice the instruction manual for the Midiman Audio Buddy says 300mA. What does it say on your power supply?
Also, I seem to get a healthy signal without turning the gain up much, but if I do turn it right up I do hear signifcant noise (no audible or light warning clipping though). I’m not sure if this is normal or not because I am a newbie.
Regards,
rathpy
Thanks, I’m not so worried about the clipping light sensitivity as I am about the signal light not coming on for XLR. Maybe my power supply is the problem(?).
So please, if you have the "M-Audio" version of the Audio Buddy, how many milliamps does your power supply say it is - 300mA or 500 ma?
Regards,
rathpy
I'll try to remember to check it the next time I'm in my studio.
From what I understand, the important thing about the milliamp rating on a piece of gear is this: if the product requires, say, 300 milliamps, you can use a power supply of the same voltage rating that is 300ma or more. You only get into trouble when you feed the device less than the minimum ma. What I don't know is how that is affected by the 240 line in your area.
What I would do is contact the manufacturer and simply ask. You might have a unit with a bad LED. Since it seems to sound OK, thats my guess.
The Ironic thing about 1000ma is that it = 1 amp. So we scoff at it but we freely will say something like 10dB. and I never hear anyone say 1 Bell.
In fact only in this measurement of sound do you even hear anyone use deca (1/10th of a full unit). to describe a unit of metric measurement.
