Using reaper, I'm trying to figure out how to get faderport working....other thing is im shopping for a better audio interface(right now I have a crappy behringer uca222)....what is the best interface under 100? What daw do ya'll use?
The Focusrite Scarlett 2i2 is ~$109 on Amazon if you can get by with 2 inputs.
Edit: Faderport - Faderport with Reaper - Cockos Confederated Forums
Does it run on MIDI? Or is it USB? I don't know, so I just threw the 2i2 out there. If it's MIDI he would need at least the 2i4 for MIDI, but that would put it up around $150 like the one you suggested. I have a Korg control surface that is MIDI, but it's USB input and set the MIDI control in my DAW - Reaper.
Then what's the argument? (I think) Reaper can have multiple MIDI interfaces. The 2i2 almost fits the 'under $100' limit the OP is asking for. That's who we're trying to help, right?Yes, The Faderport is usb but it is not in itself a MIDI interface. ...
All true but if you don't have a DIN MIDI interface you cannot use non-usb devices such as the old Yamaha keyboard I picked up for a nifty.
They do make a MIDI to USB connector (they do require a driver on Windows, not sure of Macs). So, if your unit doesn't have a MIDI DIN, you can try one of these. I have used one and had no issues, but that doesn't mean there won't be any.
Yes, I have had that response before but as you say, you were quite lucky, I have read of driver and other issues with the devices. In any case, think on! IIRC they want about 20quid for a usb MIDI interface but Focusrite want nearly 50quid to bolt one on! We are being bolted up!
And apart from that it is yet another dangly bit to get in the breeding way.
If you're price range is set in concrete, one that I just thought of is the Roland Tri-Capture.....other thing is im shopping for a better audio interface(right now I have a crappy behringer uca222)....what is the best interface under 100? What daw do ya'll use?
Really Cin'? No brainer for me!That;s really a very tough call.
