FA Millennia Media HV-3 Mic Preamp, Excellent Condition!
  • Thread starter Thread starter sunflute
sunflute
Hello Everyone, this is up on Ebay, Thank you for looking... and bidding! :)
Millennia Media HV-3 Stereo Mic Preamp
Fabulous sounding preamplifier in excellent condition.
The standard for clean, transparent preamps.
It was recently checked at Millennia Media and upgraded with DC Input Option for ideal performance with dynamic and ribbon microphones. Was also upgraded for higher gain (78 dB). I bought this preamp used less than a year ago and I only used it on one project. This preamp sounds great.
Product Highlights
HIGH SPEED TRANSFORMERLESS DESIGN
23 dB INPUT & 32 dB OUTPUT HEADROOM
NO PADS (ATTENUATORS) REQUIRED
ENTIRELY BALANCED AUDIO PATH
LASER TRIMMED FET-BASED OUTPUT
THD+N LESS THAN 5 PPM (.0005%)
MATCHED DISCRETE TRANSISTOR OCTET FRONT-END
"DC INPUTS" — IDEAL FOR RIBBON MICS
PRECISION COMPONENTRY THROUGHOUT
GOLD AUDIO CONNECTORS & SWITCHES
STANDARD 36-STEP GAIN CONTROL (1.5 dB PER STEP)
STEREO GAIN MATCHED TO .08 dB
OFC AUDIO WIRING, SILVER TEFLON POWER WIRING
ULTRA-CLEAN TOROID POWER SUPPLY
WELDED 16 GAUGE STEEL RACK CHASSIS
UNSURPASSED AMBIENCE RETRIEVAL
EFFORTLESS, LIFELIKE MUSICAL PERFORMANCE AT ALL DYNAMIC LEVELS
Product Specifications
MINIMUM GAIN 8.5 dB
MAXIMUM GAIN (1.5 dB per step, 36 steps)
60.5 dB (up to 78 dB on rqst)
FREQUENCY RESPONSE +0 / -3 dB
sub 4 Hz to beyond 300 kHz
FREQUENCY RESPONSE, STEREO DEVIATION < .04 dB
NOISE @ 60 dB Gain, 10 Hz - 30 kHz, Inputs common -133 dB EIN
NOISE @ 60 dB Gain, 10 Hz - 30 kHz, 50 Ohm Source -130 dB EIN
NOISE @ 60 dB Gain, 10 Hz - 30 kHz, 150 Ohm Source -128 dB EIN
TOTAL HARMONIC DISTORTION + NOISE, 35 dB Gain, 10 Hz - 20 kHz bandwidth, +27 dBu Out < .001%, Typ. < .0005% (< 5 PPM)
INTERMODULATION DISTORTION (50 Hz & 7 kHz) 35 dB Gain, +27 dBu Out < .0009%
PHASE RESPONSE 35 dB Gain, 50 Hz - 20 kHz bandwdth, +27 dBu Out < 2 degrees deviation
PHASE RESPONSE, STEREO DEVIATION 35 dB Gain, 20 Hz - 40 kHz bandwidth, +27 dBu Out < 1/2 degree deviation
COMMON MODE REJECTION RATIO 35 dB Gain, 10 Hz - 20 kHz bandwidth, 100 mV C.M. > 65 dB, Typ > 85 dB
SLEW RATE 35 dB Gain, +27 dBu Out > 25 Volts per microsecond
MAXIMUM INPUT LEVEL 20 Hz - 40 kHz +23 dBu*
MAXIMUM OUTPUT LEVEL 20 Hz - 40 kHz +32 dBu
INTERCHANNEL CROSSTALK 35 dB Gain, 1 kHz, +27 dBu All Outputs Better than -120 dB (> 20 Bits)
PHANTOM INPUT IMPEDANCE @ 20 Hz 6,700 Ohms
PHANTOM INPUT IMPEDANCE @ 20 kHz 6,800 Ohms
OUTPUT IMPEDANCE 24.3 ohms (x2)
+48 VDC, +/- 2 VDC
POWER CONSUMPTION, MAXIMUM 45 Watts, Maximum
POWER REQUIREMENTS 100 to 240 VAC, 50/60 Hz
DIMENSIONS 19" W x 12" D x 3.5" H
