EZ Drummer POP/ROCK Kit how to transform into awesome deathmetal/death core kit.
  • Thread starter Thread starter screwedsquirrel
screwedsquirrel
Hey there,
This is something that I had monkeyed with for quite sometime and then found a great and easy solution. I thought I might share some knowledge for those of you who are looking to start.
First and foremost you must have EZDrummer installed and have the kit set up on a multi channel setting. You can learn how to do by going to youtube and searching "ezdrummer multitrack cubase". First vid should do it.
When selecting which tracks to assign to each sample i usually do the following.
Track 1: Bass
Track 2: Snare top and bottom
Track 3: highat
Track 4:tom 1 (pan left)
Track 5:tom 2 (middle)
Track 6:tom 3 (pan right)
Track 7: overhead
Track 8:room
Next for each track, on the left hand side clikc the "inserts" tab. Add a multiband compressor.
For each track there are presets in the multiband compressor for each drum ie. bass, snare etc. sometimes u might like the snare multiband compressor preset on the bass its entirely up to you to try and find your grove.
After you have done that open the EQ tab and adjust slightly the levels you prefer. Should help out a bit.
The multiband compressor on a VST drum machine I find always sounds spectacular. Especially EZDrummer POP/Rock Kit. Gives a very thick and boulging sound which is preveleant in a lot of death metal and death core these days.
PLEASE NOTE: You must have a full version of cubase to have a multiband compressor. I recently purchased Cubase le5 and was greatly disappointed as it does not allow multi channel tracks for VST instruments. **thumbs down**
Hope that helps! Feel free to add anything you think might help others in the future.
I just recorded a song today with EZ Drummer POP/ROCK kit and can't wait to try this! Thanks!!!
add reverb on snare track, makes it deep, full and more realistic.
Parallel compression works well with EZD. There are no presets for this however. :D
Best tip for EZDrummer: Turn the room mic down until you just can't hear it and leave it there.
Best tip for EZDrummer default rock drums: Turn them down until you just can't hear it and leave it there.
Seriously.
By the way, Addictive drums is $99 at sweetwater at the moment and AD>EZ drummer by a long mile.
And presets are fail. Learn what your doing, it goes a lot further in getting the sounds you want.
Seriously.
Just to clarify; Chili said to turn the room mic down in the EZD mixer. This mic typically sounds like crap. I'm not sure how his quote got changed to "turn them down". Though it is funny, the original quote was the valid suggestion.
I re quoted to be funny and sarcastic, it wasn't meant to be taken seriously.
I really hate the ez drummer default kit (no matter what is done after the fact, that snare makes me want to punch babies). I can't believe Devin Townsend used it on a record.
LOL! I agree. I will use EZD to make basic beats for writing songs, but the first thing I do is replace the snare with SS Trigger.
LOL, I didn't even notice you changed the quote. :o I've got the SSD stuff also and love the triple snare. I should figure out how to replace the snare in ezd with it.
When you do, let us know how! :D
I actually just picked up AD. If I can find some batteries, I'll throw up a youtube comparison of AD and EZ drummer's default rock kit played badly through my roland (I'm not a drummer by any stretch of the imagination).
I assume you could just trigger SSD with the EZD snare. Like I said, I just replace it with Trigger. It would be nice if we could just swap out the EZD samples with something that doesn't make babies cry from G's punching!:eek:
Hmmmm I'm beginning to venture into a more electronic rock kind of feel...and I wanted to get a flexible drum program that has the typical rock sounds but also lets me get a little funky with some electronica type of drums too. Would either AD or EZ be good for what I'm trying to do?
The one thing good about EZD is you can go from nothing to a useable drum track in minutes. I think the kits sound pretty good, I hear G's complaint about the snare; but while not great, it's never bothered me enough to switch. EZD has an Electronic expansion patch. Haven't heard it before, but for sure they have samples on their website. I don't know enough about AD to advise.
