SuicideNote said:
I love the guitar sounds and would love to know what your signal path for them was and what you did to process them. The drums, hmm, can drummers actually do that? So brutal, good job!
Guitar signal path:
Jackson SL2H soloist with Seymour Duncan JB pickup >
MXR Wylde Overdrive for a clean boost >
Peavey 5150 II >
Marshall 2x12 cab >
SM57 on axis, 2" out of center >
Brent Averill 312a mic pre >
M-Audio Delta 1010 >
Sonar 5
I recorded 4 tracks, 2 hard panned left, 2 right. I varied the tone somewhat for each pair of tracks.
The only processing I did was EQ, a hi-pass filter at about 80 hz, a wide boost of about 2 db centered around 4k just too make up a little bite which I wouldn't normally do, but when I was mixing I started to think that I had the mic too far out of center, plus I'm still getting used to my new 312a pre.
Also, there is a somewhat narrow cut of about 3 db at around 250hz to cut out a little boom.
Thanks, and yes....drummers can do that.
