External mic preamp use with Tascam 244
  • Thread starter Thread starter Illsidgus
Illsidgus
Illsidgus
Desiccated Member
Hello All, I am new to this forum and have enjoyed reading the different threads. I have a question though. I have a Tascam 244, which I bought new in 1985, but never had a good studio mic to use with it. I just recently purchased an Audio Technica at2035 and a used Behringer mic-100 preamp, mostly for the phantom power, and was wondering if the use of an external preamp could damage the 244 preamp circuits? I ask that because I came across a blog some time ago that said that an external preamp would damage the 244. I haven't been able to verify this, I have even contacted Tascam out in California but have not received a reply. I would appreciate any help. I will not hook the preamp to my 244 until I know for sure. Or should I just get a phantom power supply and skip the preamp?
If you gain stage properly, I can't see you damaging the 244 which has a pad and trim control to manage the incoming signal strength. Get a handle on understanding input and out levels and you'll be fine.
Cheers! :)
There are no problems at all with using the MC100 with the 244. Use the ¼” output with a standard ¼” plug. The cable should be ¼” on one end and RCA on the other, which I’ll explain in a moment. The output of the MC100 is balanced TRS, but using a cable with a standard ¼” plug will bridge the ring and sleeve as it should to make it suitable for the unbalanced input of the 244.
You also want to bypass the pres on the 244, so remove the jumper for the Access Send/Receive on the back of the 244 for the channel you want to use. Plug the RCA side of the cable into the RCV (Receive) RCA jack. You’ll be bypassing the first stage preamp and trim control on the 244. Otherwise you’d be using the external pres on top of the 244’s mic pre, which defeats the purpose of using an external pre. You can plug it into the regular ¼” input on the 244 and just back off the trim control, but you won’t be getting the straight sound of the external pre without the coloring of the 244 pre.
The signal also bypasses the channel overload LED on the 244 so adjust your levels with reference to what the MC100 is telling you as well as the VU on the 244. The signal will come in right before the EQ section on that channel of the 244.
Set the channel input slider on the 244 to nominal level between 7 & 8. Start with the output control on the MC100 set to minimum and then bring it up until it’s where you want it on the VU meter for that channel on the 244. The output control of the MC100 will now be you trim control for that channel of the 244.
I once owned the 244 for a while, but soon upgraded to the 246, which I still have and have owned since new. It’s a bit easier on the 246 because it has a couple line inputs that bypass the first stage and the trim control.
That Behringer MC100 is not a bad little unit… to my surprise, and for the price, you can hardly pass it up. Do yourself a favor though and replace the stock 12AX7 tube with a JJ Tesla ECC83S.
Bottom line is you have an output control on the MC100 that you can turn to zero, so you can't damage anything on the 244 as long as you don't crank everything to max. And even then the most you'll probably get is sucky sound until you back the levels down to a reasonable signal.
Best of luck
