Exporting Audio in Cakewalk
  • Thread starter Thread starter DoritoBag
D
DoritoBag
im having a weird problem that ive never had before and it just started happening. when i finish a song and go to export the audio into mp3 it breaks it down into 2 seperate "A" and "B" files. in other words sone of the tracks are on A and the other tracks are on B, so i cant get the full song exported all together. please tell me yall know whats goin on cause i dont. thanks a bunch.
-eddy
when you open the export audio dialouge box, under where you have "mp3" checked there`s a box called format, select the "stereo files" option.
If it's not what Toki said, then in the same dialogue box he referred to, look down at the bottom and see if you have more than one Source Bus showing.
If you do, that means that you have some of your Tracks set to a different VMain than the others. You can either go back into the project and set all your tracks to the same VMain, or you can uncheck the box that says "each source to a separate submix."
dang that scared me. I didnt know you were back there Master Dach' ! :)
Yep that's something I didnt think of at all, and it could be the case..
