Experienced Newbie - Tascam Dm24 To Digi002 Rack As Pro Tools Control Surface
  • Thread starter Thread starter ltrain2015
L
ltrain2015
Hello,
I could use some assistance setting up my DM-24 as a control surface for Pro Tools v8.0. Below are the steps I've taken so far to no avail.
First - My Setup:
Digi002 Rack MIDI IN --> DM-24 MIDI OUT
Digi002 Rack MIDI OUT --> DM-24 MIDI IN
My Steps:
1. Pro Tools 8.0 --> Setup --> Peripherals --> MIDI Controllers:
Type = HUI, Receive From = DigiDesign Digi 002 port 1, Send To = DigiDesign Digi 001 port 1
2. DM-24 Machine Control List: State = X, Device = M HUI Emulate, ID = 01, Chase = --, TRA = O (Empty Circle), REC = (--).
3. External Control List: State = X, Device = M HUI Emulate, ID = 01, MIDI Rx = Checked, Screen = (Arrow to Right for sub menu)
When I try to enable the TRA, I get "Device Not Active"
And in Pro Tools, I get:
"Pro Tools is unable to communicate with HUI. Power-cycle HUI and check its connections. Note, If HUI is not in use. update the Peripherals dialog to prevent further warnings.
I tried doing a communication test in Diagnostic mode and MIDI Out = Complete/OK.
I've also tried swapping out MIDI cables but the original ones are perfectly good.
Thank you for any help...
Is MIDI send/receive turned on in the Tascam and set to the same MIDI channel as PT???
Thanks for the response...
I've checked the MIDI pages on the Tascam and everything seems to be in order. I found a setup guide online that shows you how to use a DM-24 with a DIGI001 as a control surface for PT. I followed this documentation and I can't get a closed loop on the DM-24.
Maybe check with PT support to see if the same feature is available in the 002. I saw one of the tutorials you mentioned and it said it would work with 002.
Do you use a MIDI utility like MIDI-OX??? If you're on a pc I would download MIDI-OX and set up through that utility. It will show you the ports that are functional and allow you to tie ports together virtually.
Reply to
