R
riot100
Hi,
I'm looking for some advice regarding where in the 'signal chain', an expander and compressor should be inserted.
I have the following equipment:
Analogue 16:8:2 Mixing desk connected to an 8 Track Fostex Digital Recorder.
JoeMeek VC6Q (Pre Amp/Comp/EQ)
JoeMeek VC3Q (Pre Amp/Comp/EQ)
Symetrix 522 (Comp/Expander/Gate)
I would like to record an Acoustic Guitar and Vocal, but not necessarily at the same time.
My signal chain was going to be Acoustic Guitar/Vocal connected to VC6Q or/and VC3Q (Using Pre-Amp and Comp) via mics,
then into the Analogue Desk.
The Expander (Symetrix 522) then connected as an Insert on the Desk.
I have no No inserts on the Groups.
Having read a bit on the 'Net, am I correct in stating that the Expander should be placed in front of the Compressor.
If so, what would be my best Signal Chain usage of these units.
Thanking You.
Thanking You.
But they're essentially one and the same - you can say that a gate is simply an expander with an infinite ratio.
