I think what he is suggesting is this: you’ll see wires inside that connect from one spot to another spot with these little plastic clips. If you wiggle those clips you’ll knock loose dust or corrosion and restore the connection. Maybe even one got jostled loose from vibration over the years.I don't think I'm following you. Can you go into more detail; like step by step? Thanks
I agree. Plus it’s important to note Mark7 has had this 388 apart and reassembled more than once. The connections are not robust and have to be handled with care. And even if doing so there can still be damage inflicted with simple disassembly.I’m not nearly as reliable troubleshooting these as SweetBeats but if I were you I’d be looking carefully for broken solder points in the areas you were just wiggling. So much old stuff has been dropped or rough-handled in its lifetime and those circuit boards get brittle—plus solder joints that weren’t perfect 50 years ago….i would even wiggle stuff while passing a signal. You might get the signal to turn on, then you can tell there’s a broken connection in that area.
I’d also deep clean that potentiometer with the correct no-solvent cleaning fluid.
