Ambi, if your local store has both sets of monitors available, do yourself a favor and go listen to both for yourself. There is no substitute for personal hearing, so others can only tell you what THEY like. If you really want a fair comparison, first acquire a Radio Shack Sound level meter. The analog version sells for about $40 US, and will pay for itself later in your studio, as well as allowing you to make informed decisions on speakers. It's a well-known fact that the human ear doesn't have a flat frequency response - as simply as possible, the softer the sound the less bass and treble percieved. What this means in real world, is that any two things you listen to for comparison, the one that is even 1 dB louder will sound better. This phenomenon is used to great advantage by un-scrupulous sales people. Say they have a better mark-up on speaker A, but speaker B is a better value. If you don't watch them, they will intentionally turn up the sound to the pair they want to sell you, so you think they have a better response. You can take two IDENTICAL sets of speakers, same program material and everything - put them behind black grille cloth so you can't see which is which, and set one pair 1 dB louder than the other, then A/B them - You'll buy the louder pair every time, even though they are the same speaker. To get away from this, you can take a sound level meter with you, have them set up the two or three choices in as quiet a room as possible, feed them the same CD source (commercial release, known by you) check each level with the sound level meter and set them to less than 1/2 dB difference, tighter if possible, centered at 85 to 90 dB, but EQUAL - Then, when you A/B the choices you will be comparing apples to apples. Also, if comparing more than two sets of speakers, set them up
A/B/C - - - - A/B/C, not
A/B/C - - - - C/B/A -
This way, the spread between any two speakers will be the same, so you won't be fooled into thinking that pair "A" has better separation/imaging. Center your head between the two speakers you're listening to each time.
The other main use for the Sound level meter is to maintain a constant mixing level, so your ears don't get fatigued and you get more consistent results. The human ear is not capable of discerning absolute sound levels, but instead it "gets used to" whatever level that is present. This means that levels can creep up durning a mix and not be noticed without outside instrumentation (Sound level meter) Remember that loudness affects percieved bass and treble response, so mixes done at louder levels will tend to be bass and treble shy, and vice-versa. This is all stuff you will become very familiar with in time, assuming you pursue your stated goals - but for now, this should help you get closer to the speakers you really need. Hope this helps - Too little money and too much needed gear is a problem we all face... Steve
