cjacek
Analogue Enthusiast
Hello,
I received some good info on this board with regards to the RE15. (Thanks Chris and others!). I just got the mic and have some questions, if you don't mind ... (1) As I recall it being said that RE15 will lose "highs" when dropped on the grille and that one should always check any "dents" before buying, I was re-examining the mic today and, I'm not sure if I'm paranoid at this point but, I think I see an ever so gentle indentation on the side of the grille OR were these just "imperfections" made at the factory ?? (Please see the attached picts). Don't get me wrong, the RE15 sounds absolutely great but I'm not sure how a "new" one sounds to compare it to. Based on these picts, do you see something to concern yourself about ? Does the grille look "normal" ?? (2) There is some reddish "stuff" on the inside of the XLR connector (tube) ... is this normal ? My new ev 635a has the same and so I assume that it's nothing to sweat about ?? (3) The "low cut" filter does what exactly ? When the switch is set down (towards the XLR connector) then it's in the "off" position ? Lastly, how can I check if the low cut filter is working correctly ? Thanks so much for your time. (several picts coming up).
Daniel
Daniel
