Ethernet board for D2424LV
  • Thread starter Thread starter arjoll
arjoll
arjoll
Hi
Has anyone got this setup? I'm in the process of installing the Ethernet card into a client's D2424LV.
The manual is very helpful - basically saying "get it installed by your Fostex dealer" - the problem is that we are doing it for a local Fostex dealer, and the local importer doesn't even know anything!
We have hooked up the power lead (five pin connector to power supply board) and the main data cable (ribbon into a multipin edge connector at each end) but I'm not sure if we need to do anything with the 'ether card' jumper which doesn't appear to be a standard pin spacing.
Any hints appreciated!
Alternatively if you have a D2424LV with Ethernet and are in the habit of pulling your gear apart :) a photo of the mainboard with the card connected would be great! As far as I can tell you need to unscrew the three analogue I/O cards and lift them out first...
Cya
Andrew
Please excuse the blatant attempt to get this back to the top of the list.
Has anyone got any experience with the D2424LV with Ethernet?
Thanks
Andrew
