Ethan Winer, I need some help!
  • Thread starter Thread starter OstiaMan
O
OstiaMan
Ethan Winer:
I have read your article and those basstraps seem very similar to the fiber glass boards I have already made.
-How can I be sure that they will solve my particular problem?
-Where and how should I actualy mount them in the room?(walls, corners, cealling)
-What exactly is the diffence betwin the 1/4 and the 1/8 plywood on the basstraps?
Thanks!!
OM,
> How can I be sure that they will solve my particular problem? <
Without seeing what you made I can't say for sure. But if you make the traps I show as described, they are guaranteed to reduce or eliminate your standing wave problems.
> Where and how should I actualy mount them in the room?(walls, corners, cealling) <
Walls mostly, as explained in the article text. I put some on my ceiling because I wanted to concentrate as many as I could in that end of the room. But for a more "normal" room you'd line the walls.
> What exactly is the diffence betwin the 1/4 and the 1/8 plywood on the basstraps? <
Are you sure you read the article? :) The traps built with 1/4-inch plywood absorb the deepest bass frequencies, and the 1/8-inch traps absorb the higher bass.
--Ethan
Thanks!
What kind wood should I use? any as long that is plywood, or some works better than others?
OM,
> What kind wood should I use? any as long that is plywood, or some works better than others? <
Any plywood will do, as long as it's not so cheap and crappy that it has open cracks and gaps on the surface.
--Ethan
