I have a Yamaha 02R mixing board that needs to be reflashed, is that the right term? I can't find anyone who can do it or how it is done and it just sits here. I have read a bit how to do it? I have had it for probably five years now in this condition. I am getting ready to take it apart and part it out. The meter bridge is probably worth what I
paid for it. I just hate to do it when it is probably such a simple fix.
I read your thread dogooder.
Re-flashing the chip is full of risks.
The second Kawai stage piano I bought (MP4), was designed with updating the memory via usb in mind, so was designed for it.
My first Kawai stage piano (MP9500), was not designed for easy updating. You coud do it through the midi connector, following a procedure to the letter. But if
anything goes wrong during the procedure, like a power cut, it would mean you're buggered. The keyboard would have to go back to the factory to be fixed.
Consequently I would not even attempt to try to update the MP9500. Leave as is.
I once worked on PC bios software development, and had to install a new bios version to a flash chip on a brand new PC motherboard. The procedure relied on the existing bios to overwrite itself. The trouble was, the new bios version had bugs, and didn't work properly. The knock-on result of this was the bios updating procedure in the bios could not work either.
The motherboard was now dead as a dodo, and would have to return to the factory for fixing.
In your case, dogooder, why would corrupted CMOS ram data effect the contents of a flash memory chip?
I would assume the chip data is still good, and look elsewhere for a fault.
If you could re-flash the chip, you could actually be splatting good data.
Consider how the mixer sets up data in the CMOS ram in the first place. It is likely to have an initializing routine embedded to fill the ram with default data.
It may be invoked by a jumper being fitted or not, during power-up.
Perhaps the manual, or support FAQs, may say something about this.
Questioning dodgy cables or cheap sockets, is a good stratergy.
All in all, don't rush into re-flashing.
