equipment connection problems
  • Thread starter Thread starter suds_10
suds_10
I have been recording for a while using the tascam dp-01fx and i have just purchased a focusrite trakmaster pro for compression purposes, the problem i have is i dont have a clue how to connect the two together, any help will be much appreciated.
many thanks
Plug your mic into the focusrite, then come out of there with a TRS 1/4" cable into one of the line ins on your tascam.
Thanks SRR which 1/4" line out do i use from the focusrite ??
Line out +4dBu, if your tascam seems like it is clipping from using that connection you can use the -10dB out.
Thanks for that i appreciate your help i will give it a try.
