REEK BROCK
MR. LAST WORD
I posted this in another forum but It seems its needed here also.
EQ REFERENCE: FREQUENCIES
50Hz
Boost: To thicken up bass drums and sub-bass parts.
Cut: Below this frequency on all vocal tracks. This should reduce the effect of any microphone 'pops'.
70-100Hz
Boost: For bass lines and bass drums.
Cut: For vocals.
General: Be wary of boosting the bass of too many tracks. Low frequency sounds are particularly vulnerable to phase cancellation between sounds of similar frequency. This can result in a net 'cut of the bass frequencies.
200-400Hz
Boost: To add warmth to vocals or to thicken a guitar sound.
Cut: To bring more clarity to vocals or to thin cymbals and higher frequency percussion.
Boost or Cut: to control the 'woody' sound of a snare.
400-800Hz
Boost: To add warmth to toms.
Boost or Cut: To control bass clarity, or to thicken or thin guitar sounds.
General: In can be worthwhile applying cut to some of the instruments in the mix to bring more clarity to the bass within the overall mix.
800Hz-1KHz
Boost: To thicken vocal tracks. At 1 KHz apply boost to add a knock to a bass drum.
1-3KHz
Boost: To make a piano more aggressive. Applying boost between 1KHz and 5KHz will also make guitars and basslines more cutting.
Cut: Apply cut between 2 KHz and 3KHz to smooth a harsh sounding vocal part.
General: This frequency range is often used to make instruments stand out in a mix.
3-6KHz
Boost: For a more 'plucked' sounding bass part. Apply boost at around 6KHz to add some definition to vocal parts and distorted guitars.
Cut: Apply cut at about 3KHz to remove the hard edge of piercing vocals. Apply cut between 5KHZ and 6KHz to dull down some parts in a mix.
6-10KHz
Boost: To sweeten vocals. The higher the frequency you boost the more 'airy/breathy' the result will be. Also boost to add definition to the sound of acoustic guitars or to add edge to synth sounds or strings or to enhance the sound of a variety of percussion sounds. For example boost this range to:
· Bring out cymbals.
· Add ring to a snare.
· Add edge to a bass drum.
10-16KHz
Boost: To make vocals more 'airy' or for crisp cymbals and percussion. Also boost this frequency to add sparkle to pads, but only if the frequency is present in the original sound, otherwise you will just be adding hiss to the recording.
80hz - rumble of the bass
100hz - thump of the kick
200hz - bottom of the guitar
250hz - warmth of the vocal
350hz - bang of the snare
400hz - body of the bass
500hz - clang of the high hat
600hz - clang of the cymbals
800hz - ping of ride cymbal
1000hz - meat of the guitar
1200hz - body of the snare
1400hz - meat of the vocal
1600hz - snap of the kick/plectrum on guitar (attack)
2500hz - wires and snap of snare
3000hz - presence of the vocal
4000hz - ring of ride cymbal/top end of bass guitar
6000hz - sizzle of the high hat
7000hz - sizzle of the cymbals
8000hz - top end of the kick
9000hz - brightness on snare and cymbals
10000hz - brightness on vocal
12000hz - air on vocal
14000hz - air on cymbals
Every mix is different music wise as is every genre, but here are some "defaults" to get you pointed in the right direction. Note that this is where the solo'd signal level should be peaking at and all of these are negative values because I assume you are mixing on digital gear.
Snare: -2db
Kick: -3db
Toms: -3db to -5db depending on the use
Overheads: -6db
Room mics: -6 to -2db depending on amount of ambience
Bass guitar: -4 to -6db
Guitar: -4db to -2db (the louder the more 'metal' you sound imho)
Vocals: -1db to -0.5db
Foreground synth parts: -3 to -2db
Background synth parts: -6db to -8db
Backing vocals: -4db to -3db
Ambient sound effects/samples: -7db to -9db
50Hz
70-100Hz
Cut: For vocals.
200-400Hz
400-800Hz
800Hz-1KHz
1-3KHz
3-6KHz
6-10KHz
10-16KHz
Snare: -2db
Kick: -3db
Overheads: -6db
