Well, Light, I can go part way with you here. First, note that I recognize your expertise in this area, which is *far* greater than mine. But- The axe I just parted ways with is an SG Supreme, a $2000 or so top-of-the-line SG. The neck was delicate and unstable, it wouldn't hold its tune after extensive set up work. It required 3 truss rod adjustments a week, and the intonation still sucked. The finish was scratched from pick abrasion within 2 days, and the clueless schmucks don't make a pick guard for it, so it has to be custom made. Its squared off frets provide somebody with kickass sustain, but are useless for playing rhythm, and actually cut my fingers enough to make them bleed! Moving the neck out on the body changes the position of the pickups relative to the bridge, and changes the sound. The headstock inlay was sloppy, as was the neck and headstock binding, and yeah, it had good pickups. Those puickups are being installed in my Epi Les Paul as we speak, which is in every respect a better axe If we were talking about some 1961 Kalamazoo classic, I'd have to admit you were 100% right, but the stuff being produced with the Gibson name on it now is a far cry from those days. Of course, as we both know, guitars are made of wood by humans, and even some underpaid Korean can luck out and build a good axe. An American in Nashville can build a wicked expensive piece of wood with a cool paint job that sucks, and charge too much for it, also.
When all is said and done, that Epi has better fit and finish than the so-called "real deal". I'll agree with you that it needs a set of pickups. That's not a problem.-Richie
