dobro
I had this problem a year ago, couldn't solve it, and gave up for a while. Okay, I'm going to solve this problem now, or I'm going to sell some gear and replace it with something that works.
I can't get my Gadgetlabs spdif add-on card to work. Gadgetlabs no longer exists, of course, so I can't contact them. I want spdif so I can process my CEP tracks with my Lexicon reverb unit. The Lexicon unit works (I took it back to the shop and had them test it in front of me). Cool Edit works. It's the Gadgetlabs soundcard spdif add-on card that's the problem.
Here's what I've tried. I did a loop test (spdif soundcard out to spdif soundcard in). I can get Cool Edit to record a new track from an existing track, but the new track has loads of clicks and pops. Each click occupies either the top or the bottom half of the onscreen waveform, but not both. Plus, this only works with the soundcard clock set as master, never as slave. Finally, and interestingly, if I switch the clock setting, I get a CEP error message that says the format I'm using is unsupported and I should convert the sample type to something compatible with the soundcard. If I switch the clock back to where it was, I get the same error message. Reloading the session doesn't change things. Reloading CEP doesn't change things either - I have to reboot the computer, then I can get it to work, although still with the clicks and pops. This suggests to me that it's definitely the soundcard. When I try using my Lexicon unit, I only get the error message, nothing else.
If somebody can help me with this, I can continue to use the Gadgetlabs soundcard, and save myself a lot of money. Otherwise, I'm going to have to ditch the Gadgetlabs card and replace it, or ditch the Lexicon and go with plugins.
