C
Chadwick
Is it OK to run electrical wire on top of coaxial cable for TV through the studs or will it create noise in the equipment plugged into the circuit it's next to?
Bad idea. It can induce interference on the coax. I'd keep it more like a foot away if you have to run parrallel and if you have to cross is, do it at 90 degree angles.Chadwick said:Is it OK to run electrical wire on top of coaxial cable for TV through the studs or will it create noise in the equipment plugged into the circuit it's next to?
