i was just looking at the TC Electronic G Major
i think it may be worth checking out
thanks
To add to that, the G Major employs relay switching. So, if you get a midi controller (I have the DMC Ground Control Pro), you can have the G Major switch your channels for you and you can keep the Big Foot for a backup.
For example, I like to have some reverb on my clean channel always. I programmed a patch on the G Major that adds reverb and sets the relay to channel one. So, when I call up that patch with my Ground Control Pro, it goes to that patch AND switches to my clean channel. And when I switch to channel two, it goes to my channel two patch, turning off the reverb in the process. I like my dirties dry.
Another good thing about the G Major is that it does not act as a preamp. Therefore, there's very minimal (if any) coloring of the sound.
Anyway, I'm not a TC Electronic employee and I'm not an endorsee. I just happen to really like
my G Major. That being said, TC should really pay me for the advertising I just did...if it made sense.
I also stand by the DMC Ground Control Pro. Best midi controller on the market. Works flawlessly with the G Major. I can switch channels, totally switch patches (program changes), or even use it like stomp boxes, turning effects on and off as I want (control changes). I also have
an Ernie Ball volume pedal connected to my Ground Control Pro that works as a midi controller for whammy effects. Just plug it up to
the Ground Control Pro and turn on the function for it and you're set.
Yet another cool thing about the Ground Control is that I only have ONE wire coming from it. That wire sends my midi data AND powers the unit so I don't have to have a power strip next to my pedal board. The cable I'm using was made for the Rocktron unit but it works great with the Ground Control. It's a 7 pin midi cable. 5 pin for the midi data and 2 pin for the power. The other end goes to my rack where the power is plugged into my Furman and the midi is plugged into my G Major
DMC should pay me, too. And I might as well get some Rocktron commission for pushing their cable.
