editing on dp 03 sd
  • Thread starter Thread starter seanvox
seanvox
Does anybody know agood way of getting your times more precisely with the in and out points ,it all seems a bit hit andmiss and alot of time adjusting back and forth. Cheers
I just recorded two new songs with 1 acoustic and 1 vocal using internal mic-B for both. The acoustic tracks had about 10-15 seconds of lead time cluttered with noises from moving the guitar.
I played back the recording, watching the display counter and could see almost exactly where the noises stopped and the guitar began. I rewound to beginning, then cut out from 00 00 00 to 1 second before where I thought the guitar would start. Played that back to check it. Then I just repeated the cuts, trimming off the last numbers by increments until I got it. That last set of numbers ranges from 0 to 29 (I'm not sure what these represent.. frames..?).
At first, I thought this process as long and complicated. Now I find myself using both hands and breezing through. This is why I like Tascam.
Anyway, I always leave plenty of room in front of the song at the initial recording so I can have room to cut. Trimming the end, I just use the Input Trims at the top to slowly fade out. If you don't bump anything, these will give you a clean fadeout - unlike dropping the sliders or pushing a button. Those Internal mics pick up every little touch of the board. Other inputs won't have that problem.
Press home and use the dial to select the time, the recorder doesn't have to be running to select in and out points
