P
pscraja
I have recorded a lecture on a mp3 recorder which has no vol. control in recording.
When I play it in cool edit pro, the amplitude is quite high. If I use the effect/amplitude and reduce the amplitude by say -3db cut, the resultant recording has a flat extremes with no change in the lower db levels.
How do I reduce the amplitude so that the whole recording is reduced by the set amount uniformly instead of cutting off the peaks only.
Can some expert guide me.
Where can I get a good tutorial on using cooledit pro especially editing.
Thanks.
pscraja
Thanks.
pscraja
