Edirol UA-25EX vs E-mu 0404 USB2 vs ProSonus Inspire????
  • Thread starter Thread starter cycadia
C
cycadia
I've narrowed down my audio interface options to these. I've pretty much looked at every available eligible model on the Australian market, and ruled out everything else for being too simple, too expensive, or just not what I'm looking for. Aus dollar doesn't buy you much.
I have a PC laptop. Not too flashy (XP over Celeron M 410 1.46Ghz with soon-to-be 1.5gig ram). Have a PCMCIA slot I could install (unpowered) Firewire adaptor into.
Any opinions? These seem fairly similar feature wise. I only need a couple of inputs at a time, either 1 preamped mic/ 1 Hi-Z instrument or 2 preamped mics. Don't care about MIDI or digital I/O right now.
How do the preamps measure up? I want to use a Shure SM58 so I need some decent gain. What about hums and buzzes? Sound quality?? Latency? Firewire and USB2.0 is a bonus, but do I really need it if I'm rarely recording more than one track at a time? Sounds like the Inspire may not be as good in terms of fending off hums on a PC laptop - the other two have balanced outs and ground-lift switches. What about driver reliability and latency? Can't find many reviews of the UA-25EX as it's a pretty new upgrade on the UA-25, still USB 1.1 though. Preamps are supposed to be quite good quality but I don't know if the gain's okay for a SM58, given it's bus powered. Sounds like the phantom power's decent though.
(xposted to CDN) Thanks if anyone's got any experience/expertise with any of these interfaces they can share. :)
ETA: ...........24 hours later, leaning towards E-mu, but I've just discovered I can get the NI Audio Kontrol 1 at a reasonable price and reviews sound good... *sigh* too many options! Thanks for the opinions!
I only have the inspire - it requires 6-pin powered firewire.
It's pretty good, but the preamps are a little noisy, which means you can hear it when you're using dynamic mics to record lower level stuff and have the preamp gain up high (past 1 o'clock, more or less). With the preamp gain down low, they sound OK. Your unit may vary. I don't know the other two.
I own an Edirol UA101, which seems to be the 25ex's big brother(?). The unit has worked very well for me - reliable, stable and buzz-free - but I'm not sure I'd go as far as agreeing with the manufacturer's description of the mic preamps as "pro-grade." They're quiet enough if a little on the dull side. I use the unit as an interface with a few other preamps.
