Echo Mona units
  • Thread starter Thread starter John Mayes
J
John Mayes
I have for sale two Echo Audio Mona units. They are in pristine condition with only rack screw marks that will be covered when racked up. Otherwise they are in GREAT condition and work perfectly. They are desktop units and come with drivers on CD, cables, and pci cards. Specs are below and I'm asking $450 per unit.
Mona is the ultimate audio production studio in a box. Its four universal inputs connect microphones, guitars, and line level audio directly to your digital audio workstation. This direct connectivity eliminates the need for external equipment, such as mixers and pre-amplifiers, which can add noise and distortion to your recordings. Mona is an affordable solution for field-recording rehearsals or local gigs, and Mona has the professional level specs high-end recording engineers demand. Mona is engineered using the latest generation 24-bit 96 kHz converters, which offer the highest dynamic range and lowest distortion available.
In addition, Mona's six balanced outputs make it an ideal digital mastering tool, and Mona's six RCA outputs allow seamless integration with your home entertainment system for applications such as 5.1 surround sound playback.
Mona comes with a 15' host cable that connects the rack mount interface to a PCI bus master interface card or CardBus card for laptops!
Hardware Features
Software Features
4 universal analog inputs with 110dB (A-weighted) dynamic range
6 analog outputs (both XLR & RCA) with 115dB (A-weighted) dynamic range
24 bit optical and coaxial S/PDIF digital I/O
ADAT optical digital I/O
Headphone output with volume control
Word clock I/O
Rack mountable single space breakout box
15' cable to connect to PC
4 high quality mic preamps with phantom power(+48v)
Trim control and level meter for each input
128x oversampling analog-to-digital converters
Full Duplex 12 channel in 14 channel out operation.
PCI or CardBus bus mastering interface
+4dBu or -10dBv analog I/O on each analog channel
Software console for monitoring, metering, and setting levels
Driver support for Windows 95/98/Me/2000/XP and Macintosh OS 8/9/X
Support for WDM, ASIO and GSIF
Low-latency drivers
Compatible with all popular recording products
Built-in digital mixer provides near-zero latency monitoring
