easy question im sure anyone can answer
  • Thread starter Thread starter Flick
F
Flick
What is a snake? and for studio purposes, why would i need one?
A snake is a bunch of cables bundled together.
So a ten cable mic snake has ten plugs on one end, ten plugs on the other end and ten cables joining them.
It is useful for running all mics from a drum kit etc. The most common use I've seen is all the mics from the stage out to the mix board.
foo
Like foo said, multiple bundled cables. It all depends on your set up.
If you have an 8 track unit like a layla that has 8 inputs and 8 outputs, your better off using snakes instead of seperate cables. Most snakes are color coded and if not you can number them. Easier to keep track of. If you have a 16 channel mixer and an 8 track unit, you can use 2 sets of 8. One set for input the other for output. You can record on the first 8 channels with the dry signal. Then channels 9 to 16 can be used for playback and mixing effects. Eq, etc. This way you have the option to change something instead of recording it wet and having to re-record something if you needed to make changes.
Another handy device when you have multiple outboard effects,compressors etc. is a patchbay.
http://www.musiciansfriend.com/srs7...7135190894/search/g=home/detail/base_id/43414
What is a snake?
