D
DownTheUpstair
Hi there, not exactly a full newbie per se, however I've been running into a problem for awhile that I can't understand though I'm sure the solution is probably something simple!
When recording into any new track in Reaper with a guitar going direct into my Focusrite Saffire 6 interface, the track is always clipping, usually by about 1 to 3 dB over 0, even though I have the Gain knob for the input I am using on the interface set to 0, with absolutely no other Gain at all in software or hardware, and a completely dry signal with no plugins or other FX enabled.
I've seen people comment on other threads about lowering the volume knob on the guitar, however I find this affects the tone which I don't like, as well as suggestions to lower the actual volume fader on the track, though I can't see how this would help as it would only lower the volume of the track and not the volume of the actual signal going into the input itself.
Someone suggested that maybe the signal going in is too hot, though this is highly unlikely as I usually use a PRS with passive pickups, and even having tried with an Ibanez using active pickups, there is not much difference between the two. If anyone could offer some sound advice (pun not intended) this would be great as I can't wait to get recording full tracks and feeling demotivated by this constant annoyance! Thanks!
HP 15 Laptop bought new last year, Windows 10 64-bit, CPU 2.16GHz, 4GB RAM
Focusrite Saffire 6 USB interface
