M
mgray
I have an SM58 and a Boss Micro BR(portable 4track). For this question I'm using the mic(with pop shield removed) to record a Vox AC-30.
I find that if I connect the SM58 to the BR Boss and select EXT(external mic) option for my input connection, I can hear clipping, even if I set the sensitivity to the lowest(-15). I can hear the clipping even though the OVER(clip) indicator doesn't light up.
If I select LIN(line) as my input, and put the sensitivity to full maximum (+8) I don't hear any clipping, and the background noise is noticeably reduced. The signal is still pretty hot.
So I guess my questions are; Is it normal for a dynamic mic's signal to be high enough to connect to a line input? And is there anything bad about connecting like this?
