Duet 2 Initial Setup!
  • Thread starter Thread starter audiodudero
A
audiodudero
Hey guys need some advice here.
My guitar sound is coming out gross - sounds terrible.
If I am going acoustic electric guitar -> duet 2 -> mac -> logic x
What are the proper input levels and settings so I can have the cleanest noise / signal coming through before effects, eq, noise gates, and compressors. Right now I get hiss and the guitar is either too quite or too loud. I want to be able to play at low volumes, but high clean harmonics, finger picking and palm mute strums and then loud strumming and guitar slapping percussion. ALL I want the signal to be as quite as possible before having to alter the track.
DUET 2 SETTINGS QUESTIONS: - BEST TUNE UP SETTINGS FOR EACH:
Input Setting: inst or -10 or +4
What should I set the DB knob to?
Should the A on the left be highlighted?
Line 1 Output +4bu or -10dbv
Line 2 Output +4bu or -10dbv
Line 1 Volume
Line 2 Volume
___________________
MIXER:
SOFTWARE RETURN VALUE:
MIXER MASTER VALUE:
_______________
SAMPLE RATE: 44.1
PEAK HOLD: 2 SECONDS
OVERHOLD
____
eLECTRIC aCOUSTIC
Volume on the pickups 1-10
____________________
Mixer SEttings:
Software Return: 0
Mixer Master: 0
_______________
LOGIC X PRO
AUDIO PREF
I/0 BUFFER - 64
RECORDING DELAY 0
24 BIT RECORDING CHECK
SOFTWARE MONITOR - CHECK
INPUT MONITOR ONLY FOCUSED TRACK AND RECORD ENABLED - CHECK
INPUT MOINTOR FOR RECORD ENABLE CHANNEL STRIP - NOT CHECKED
PROCESSING THREAD: AUTO
PROCESS BUFFER FLANGE: MEDIUM
REWIRE BEHAVIOR: OFF
MAXIMUM SCRUB SPEED: NORMAL
SCRUB RESPONSE: NORMAL
Please help - I know long question - but I will take your valuable information to the grave!!
ALSO: If you have a good looking track record / CV and you want to take the time to fill this information out for me PM me and we can discuss rates for your time.
Please HELP!
Advice? Don't do what you're doing.
Acoustic guitar pickups - they're for live work, not recording. Use a microphone.
Sorry to be the bearer of grim tidings....:guitar:;)
