D
dave@soundmind
new to site so hello everybody,
this song is called: " the elite "
topic: political
recording info-
vocals: bottom of the line akg large condensor miked about 12 inches from source, slightly off axis, mindprint envoice preamp, low cut eq, fast compression 7:1 -16 threshold. waves plate reverb, de-esser
drums: break beat recycled then played on keyboard (logic esx24) with an additional kick layered for more low end. small room reverb with the effect return low and high cut to only reverberate frequencies between about 1.5k to 5k
bass: direct with compression
guitars: cabinet miked with sm57 about 2 inches from source, 45 degrees off axis blended with a seperate recording of direct panned opposite of the amp recording.
melodica: miked 2 inches from source with condensor
dj cuts: flanged reverb
keys: proteus 2k
interface to logic: delta omni studio (windows)
and a bus of the entire mix into a hard limiter and slightly blended back in with the mix
please disregard the delay at the end of the hook (gotta redo)
any opinions on mix/performance/arrangements/songwriting?
topic: political
recording info-
keys: proteus 2k
