Dry recording input levels on BR8
  • Thread starter Thread starter gtrist
G
gtrist
Hey to all,
I set the Effects to dry recording, track 1. I am using a Shure 57 to record my Hot Rod Deville amp, which is set at 3, plenty loud enough. I have the mic plugged into the vocal 1. Question, I set the input level to record at center 12, when I play it back the volume is to low, but when I switch back to input/normal and add effects it is where it should be. However I want to have my amp sound without the effects. I turned up the input on both to a point where the meter was showing way to hot, but when I played it back, the volume was still to low. Any suggestions out there.
Doug
