ecktronic
Mixing and Mastering.
Does anyone knwo if Drumagogg has a way of leveling out a drum track rather than replacing and leveling out a drum track?
Cheers.
Eck
Cheers.
Eck
No, it only levels it if you replace the sound.ecktronic said:Does anyone knwo if Drumagogg has a way of leveling out a drum track rather than replacing and leveling out a drum track?
Cheers.
Eck
ecktronic said:So there is no such thing as a drum leveler?
ecktronic said:Compression doesnt cut it for this really. I compressed the shit out of the tracks and they still arent level enough.
Would be a good idea though. Would save having to use a compressor.
Eck
chessrock said:Actually, there is a piece of gear that most of the dipshits on this board aren't hip to.
And it's made by Aphex. It's called the Compellor. You should check it out. And no, it's not a compressor. It's a leveler / compounder. It's function is to even out the volume on things. Like drum hits, for example (hint hint).
I use Waves Renaisance compressor and I have a good idea of how to use it. Ive been using it for the last 3 years.Freudian Slip said:Maybe you're not setting up the compressor right? Are you using software or hardware compression. I have never had a problem leveling out kick or snare.
If you can you may see if your compressor is on rms or peak. if it's on rms try switching it to peak.
F.S.
ecktronic said:I use Waves Renaisance compressor and I have a good idea of how to use it. Ive been using it for the last 3 years.
Attack: 5ms Release around: 140ms (depending on the tempo of the track and how fast the kick is hit)
Ratio around 4:1 threshold pretty lo, like around -20dB
Eck
Eck
I agree with waves L2. I have used it for just this purpose and for me, the times I have used it ,it worked well. Track slammer setting is what I use.Freudian Slip said:Do you have or have you tried L2 or maybe put it after Renaissance?
Just a thought.
F.S.
jmorris said:I agree with waves L2. I have used it for just this purpose and for me, the times I have used it ,it worked well. Track slammer setting is what I use.
ecktronic said:Cheers all for your info.
I use L2 on the master out, but that only cuts off the tops of the waves rather than leveling te hits though.
Eck
Eck
