Drumagog experts
  • Thread starter Thread starter Bulls Hit
B
Bulls Hit
I may have to reinstall XP on my DAW.
I'm wondering if there's a way to save all the Drumagog presets I've accumulated over the last couple of years so they'll be available when I reinstall...?
You should be able to, depending on the sequencing software you are using.
I don't believe Drumagog saves the presets itself (only the gog files). The presets are saved within your sequencing programs directories. DirectX version presets will be a .DXP file. Doing a search of your drives for a few of your presets should turn up the locations.
At least that's my take on it.
Maybe Farview will chime in with some of his knowledge on the subject.
They should be fxb files. (at least they are on my system) I'm in the middle of a large hard drive problem and can't get nuendo up right now. In wavelab, it saves them as fxb files. You saved the presets, you should know where they are on your system. If you don't, go to save a preset and read the path that you are saving stuff to. That is where they will be.
Hey thanks guys, that's a help.
In GT pro, they just get saved along with the factory presets. I'll do a search see if I can find 'em
